VRay Clouds color/brightness options
Hi team! I’ve excitedly been playing around with the new Clouds option in vray sun, so I can hopefully replace generic HDRI usage with geolocated daylight systems. The clouds look decent so far. I happen to have very picky clients that like “happy little clouds” and complain when clouds are too gloomy (like the vraySky image attached) and don’t look like fluffy white cotton balls (like the attached image using HDRI). I’ve tried adjusting sun angle, skylights, camera position and exposure, frame buffer color correction…but can’t seem to get the clouds to look brighter but not blown out. I can probably just use the alpha channel and color correct in post, but it seems like there might be more use cases to be able to adjust cloud color and brightness within vray. Curious is anyone else sees value in this. Cheers!
There are plans for some additional control over the darkness/brightness of the clouds.
