Vray Decal
All of a sudden no matter what I do the vray decals show a sort of “shadow” or stamp of darker color. I even used decals from the cosmos browser and still the bock of the decal prints on the surface. What am I missing?
This doesn’t seem right. I tried reproducing the issue with the same decal, but I get correct results regardless of whether there is a bump on the host surface. Mind if you attach the scene so I can have a look?
I have this same issue and it is driving me insane!!
Strange I tried to replicate it but can’t seem to break it. Works fine here with latest V-Ray, which version are you using?
The only way I managed to recreate something similar was when the host material had a VRayNormalMap that was empty (no bitmaps connected). @jack_griffiths1 I’ve replied to your ticket, requesting the scene textures, so I can continue troubleshooting.
In my experience this happens if you set a normal map with an intensity bigger than 1 in the vraynormal map intensity and or bigger of 100 in the Vraymat bump slot.
I tried both, with extreme settings in my initial tests and that wasn’t it, at least not in this case.
