VRay Distance doesn't consider objects loaded from vrscenes
Hi!
It seems that VRay Distance doesn’t consider objects loaded from VRayScenes.
When I load the object cached from a VRayScene, vray doesn’t render the DistanceTex, when I feed in the live cooked unchached object, the DistanceTex renders well.
Can you confirm this? Is there a workarround?
I don’t like to leave the heavy uncached object in the scene just for generating the DistanceTex. So it would be cool if DistanceTex could work with objects comming from a VRayScene, too.
Thank you and greetings!
VRay Distance works only with mesh object. There is no way to make it work with the VRayScene.
As a supplement to what Andrei has written - maybe an option to work around this limitation would be to load your VRScene a second time in a separate Geometry node and use the “Unpack to Polygons” to extract the specific object you need to work with the distance texture. At this point it will be treated as a regular mesh.
In terms of times to first pixel, ideally you’d cache it out as an Alembic file, too.
Best regards!
Thanks, I’ll try :)!
