Vray EDU v. Commercial and Windows 7
Ok, 2 questions on my mind and I figured I’d try to knock them both out in one msg to reduce hassle.
1) Are there any functional differences between Vray for Rhino Educational Version and the Commercial version? Any watermarking, size limits, etc. etc. that would make me as a student want to get the commercial version over the educational version?
2) Once Windows 7 gets released here in a few months, will I be able to use my Rhino and Vray for Rhino along with it, or will I have to wait a while for all new versions of these?
Thanks!
~Matt
Re: Vray EDU v. Commercial and Windows 7
I’ve used Windows7 since the beta - I’ve had no problems with any of the apps I use. If it worked on Vista it’ll most likely work on Win7.
Hi Matt
There no limitation or differences between the Commercial and EDU version in term of features. The only limitation is that you can not use the educational version for commercial purposes.
Best
Thank you both…those were both the answers I was hoping for!
But the educational version of Rhino can be used in commercial porpouse…so I should have Rhino Edu + VFR commercial?
