Vray error
I render images through the Vray buffer only to be greeted with a ‘Cannot create Bitmap’ error when I try and save to file.
Any suggestions?
This error is generated by 3ds Max when there is no sufficient memory to copy the bitmap so that it can be saved. A work-around (other than using a 64-bit version of the software) is to enable the 3ds Max Bitmap Pager for 3ds Max 2009 and below from the render settings in the Preferences dialog (the Bitmap Pager is always enabled in 3ds Max 2010).
