I have a simple max scene with one vrayphysicalcamera, a sun and vraysky and can’t make work the Vray Exposure Control on it. I’m using MAX 2013 PU5 and VRay 2.30.01.
Anyone have the same problem.
Thank you
Chris
Do you have the exposure toggle on, in your camera settings dialog? [quote=“animator75, post:3, topic:39359, username:animator75”]
Thank you
Chris
[/quote]
yes, it’s on
the rendering with the vrayphysicalcamera have the good exposure. Using the perspective/orthographic view is overexposed.
Got it.
Is the “Use 3ds Max photometric scale” global switch that must be ON.
Vlado, maybe it will be useful to clarify this behavior in vray 2.x help
Thank you
Thanks for the pointer; will add it there.
