No matter which view I’m currently opening, plan, section, elevation, 3d parallel, 3d perspective, sheet view, the tab is always in grey. I tried several times to uninstall and re-install it, didn’t work at all.
My Revit version is 2017.2.2.
Any advice will be appreciated.
Thank you
Sarphi
Simply click on the Acquire license button.
See questions 4 & 5 in our FAQ: Chaos Docs
Sorry, typo, should be Ana, not any
Seems that the license server is correctly activated, so - make sure you have the correct build downloaded and installed ( “V-Ray 3.50.02 for Revit 15, 16, 17 and 18 TRIAL” in your case - can be downloaded from https://download.chaosgroup.com/ )
Also - the license settings should point to the computer that has V-Ray license server installed - Chaos Docs
If that’s the same computer you use Revit and V-Ray on - you can use “localhost” or it’s default IP address 127.0.0.1 in the license server configuration.
After you make changes - restart Revit and try acquiring a license.
Try right clicking on “Change V-Ray Client License Settings” and Run as Administrator.
Mark
