Vray Frame Buffer - Progammic Load / Save of .vfbl files.
Please give max script access to loading a “layer tree preset” and saving a “layer tree preset” after the user makes adjustments. I just don’t trust users to type filenames.
The .vfbl file
There are two buttons on the interface that do this
This seems to work (tested in V-Ray 5 Update 1, 3ds max 2021).
vfbControl #saveglobalccpreset "C:\\temp\\test.vfbl"
vfbControl #loadglobalccpreset "C:\\temp\\test.vfbl"
I was actually looking for the command to save a LUT (which used to be the same command in Next, but that seems to be still missing).
Daniel
SWEET!
Thanks. documentation states those interfaces are for .vccglb files
I would have never thought to and didn’t try loading an undocumented file type into them.
So that interface loads both then? I see a whole bunch of new color corrector maxscript controls, which is interesting as the interface seems to be gone.
Did you see this post, @KramSurfer ?
You’ll need to get the manager interface, and work with its methods and sub-interfaces.
He did, that is why he posted “I found out i can load the .vfbl into the old interface still documented for the .vccglb” to the other thread, based on my comment.
Daniel
The double thread was confusing me, clearly.
Thanks for bothering.
