I try to animate some splines which is visible in render at frame 0 vray render well but after that frame vray freeze with all display is 99:99:99 at frame 99…
I could be wrong but check if the splines are using adaptive interpolation - as the splines animate they could be changing vertex count and making vray freak out - especially if you’re rendering with motion blur.
I looked but the parameters has unchecked and I unchecked the optimize to see but I have the same result…
thanks for your help Joconnell
Does anyone can make a test with vray 1.50 sp1 :
-simply create a spline
-enable in renderer and in viewport
-add a thickness
-animate some point of the spline
- Render using vray and see the result
Regards
Mickael Attia
Ps : I am using vista 64 bits and 3sdmax 9 64 bits
Can you send me a private message with your email address so that I can check what happened with this? It is possible that they replied, but you didn’t receive it.
