When I use the vray fur I can’t seem to assign a material or map to it. is there a way to do this?
Select the VrayFur Helper (square thing in the viewport) Then in the material editor, use the assign material to selection button.
vray fur
what about mapping coordinates?
The hair will derive its mapping coordinates from the object it is applied on. Additionally, there is an option to modify the W coordinate to be between 0.0 and 1.0 along the fur strands.
vray fur
thnaks that helps a lot.
