Hello All
Should gpu rendering and cpu rendering look the same? my gpu rendering is over saturated compared to the cpu version
thanks in advance
matt
Hello All
thanks in advance
matt
They are two different engines are results are not expected to render 1:1. Still, the difference that you see can be a bug. Do you have a sample scene that illustrates the problem, so we can check here if it is expected or not ?
Best,
Blago.
hello,
Please find attached a test scene, the issue is with the stochastic material
please see attached file
thanks
matt
chaosgroup.zip (739 KB)
Thanks a lot for the scene!
The reason for the differences on the stochastic flakes shader seems to be cause by the additive mode of the top-most blend material (this one). It most likely a bug and I have logged that.
Best,
Blago.
ah cool thanks for that
cheers
matt
