Latest versions.
Running GPU and it renders perfectly and is visible in the viewport but doesn’t render in Vantage. See image. It appears the gradient ramp isn’t being processed at all. Any suggestions would be greatly appreciated.
Thank you
I did read a post back in 5/23 that blend isn’t supported. My guess is that’s the issue.
Yes, the blend material is not supported, but we are working on it for the next release.
The solution without the blend material is better in any case - it will have less sampling noise.
Greetings,
Vladimir Nedev
Good to know. Thank you very much.
