Does this work correctly on Vray GPU (current update) ?
I can instance one vdb loaded with a volume grid and it renders fine but as soon as I try to make more intances it displays the others but wont render them.
How does this work?
How does this work?
V-Ray GPU currently has the limitation of having only for 4 overlapping volumes. It is fine to have as many volumes as you like in the scene, just when they are overlapping we need them to be maximum 4 volume in one place.
If your scene has no overlapping volumes can you send it over so we can check out what is going on?
Thanks,
Ah ok then its cos they were overlapping cloud volumes stacked over each other. Thanks
