vray grass
Memory
If you read your log it’ll give you a warning if you memory is to low.
So what value is the most reasonable, if I have 3 GB of RAM installed on my x64 OS? Are there any workarounds on this?
By the way. The Fur-Image with the Tomatoes, it’s really well done. Thank you for sharing your Fur settings with us.
And what about 32 bit machines? Say, my laptop with 2Gb RAM?
What about computing LC for secondary gi? This usually takes ages for fur,even on a nice dual quadcore with 6 gigs of ram (xp64).
Like I mentioned above, I had to use IR/Brute Force instead of LC, because the LC looked like it was going to take hours.
looks good pixelstudio but where are your tomatoes…
where did the taper option go in 1.50?? any fixes?
walkstar
I have a taper option in 1.5 SP1. Look at my settings on page 2 of this thread.
Maybe taper was added with SP1? The fix would be to upgrade…
