vRay IES lights - shadow problem
I’m facing a weird and serious problem here, on a tight deadline ! please check the enclosed rendering … apparently, vRay IES lights shadows produce some banding / hard edges shadows ! have you guys ever got this problem ? is there a way to solve that, please ?
Thanks a lot for any help !
Regards.
Have you tried other IES light files ??? The one you have may be currupt/faulty.
There seems to be a lot of variation in how IES files are written but I have never seen issues like this before.
Thanks for your suggestion. I’ve tested the same IES file, but in a simple scene (only light / cylinder / plane), and I don’t get the problem … must be something in the scene :frowning: but I haven’t found yet.
Thanks again.
You can try to set cutoff to 0 instead of 0,001
Thks Nils, I’ll try that too :slight_smile: but won’t that have a negative impact on rendertime ?
I think it does. Vlado probably has the right answer for this.
Ok :slight_smile:
But once again, it’s really weird: when I try this exact same IES light in a simple scene, with plane and cylinder - it’s perfect. Only in “full” scenes with many lights, I get this behavior :frowning:
Thanks again for your suggestion :wink:
Regards.
