egz
September 28, 2003, 8:50pm
41
Small update posted
Changes in 0.6:
Added support for affect shadow and affect alpha in the glass material.
Made the color pickers non-modal
Added the first version of the object light material.
For best results, adjust the RGB multiplier until the object looks correct in reflections, then increase the GI multiplier if you need more illumination. The defaults here will most likely change later.
Grab the update here: http://vray.info/materialbeta.asp
Remember to remove the previous version first.
thx, egz! but how to remove the previous version?
marina
September 29, 2003, 3:43pm
43
Delete it from scripts\startup folder
egz
September 29, 2003, 3:45pm
44
The instructions are on the download page…
egz
September 29, 2003, 3:46pm
45
hehe, Marina beat me to it
Very cool initiative, Torgeir! The materials are a great help for speeding up workflow. Thanks!
Cheers,
Metin
sc:
question for you though, any chance of adding a specular highlight control back into the material? I’m not very fond of using the shellac material because it complicates your materials. I presume the more complex your material the slower it gets too.
I second the request for a Metal shader, preferrable a nice brushed metal with nice specular highlights for flat surfaces..ooohhhh yeah!!!
I second the above:
a) specular back into the shader
b) a nice/ qick brush metal with spec highlight for flat surfaces…
thanks much egz!!! throughly appreciate you generosity and time for puting these together!
paul.
Basse
October 6, 2003, 5:30am
50
Get max script error when trying loading carpaint.
I use max 5.1 and Vray 1.09.03m
It says:n -Runtime error: Not creatable: Falloff
3dform
October 6, 2003, 7:59am
51
Could you add a: turn into standart Vray material function?
That would help a lot…
robert
i use max 5.0 and the newest vray. i downloaded the materials installed them and tried to render the sample scene, but theres only a white picture with nothing in it when rendering is finished. Sorry for my poor english im from german.
anyone able to help me?
egz
October 9, 2003, 1:04pm
53
Maybe something has changed between 5.0 and 5.1?
Are you sure you are rendering the correct viewport?
Do you get an alpha channel?
586
October 9, 2003, 3:18pm
54
Torgeir, you’ve been impossible to reach! How were the renders that I sent you?
egz
October 9, 2003, 3:41pm
55
Keith!
Sorry about that The renders were great! Thanks.
BTW, I’m still on ICQ every day, so I’m not that hard to reach
i dont know what you mean with alpha but i think i dont get anything. Do i have to switch something on or off? or should i try to install the max 5.1 update?
egz
October 9, 2003, 3:46pm
57
YES!! 5.1 fixes a lot of issues.
586
October 9, 2003, 5:10pm
58
Great! Glad to hear it. I’m not usually on chat anymore, so I guess that makes _me_ the hard-to-reach guy…
installed 5.1 and still nothing, renders only a white picture
egz
October 9, 2003, 6:29pm
60
when you open the file, are you getting the units conversion dialog? If so, do you scale, or use file units?
