Vray instalation problem
Hi.
I need some trick about vray installation.
We are in migration on max 2008 but we keep max 9 installed for the moment.
The problem is when we want to install Vray on max 2008, the installation detect max 9 installation and want to remove it.
Is there a trick to have Vray installed on both Max 9 and Max 2008 on the same workstation?
Thanks.
as mentioned before, if the setup detected an installed version just click
okey. the “uninstall” setup launces. then click cancel and vray will be installed
very simple.
Thanks.
