during testing the vray lens effect, in DR mode it seems no working correctly…
any tipps to solve this??
best regards
chris
Are you 100% sure you installed vray 2.0 on all nodes? (thats what happened to me anyway
Works for me on a simple test. What Peter said - make sure you have updated all the render slaves.
hello vlado,
on all nodes I installed the version downloaded today 9.00 am…
Ok then; does it work on a simpler scene?
plus, does it only happen on 1 node, or all nodes? Add a VRayDRBucket element to find out
I give it try and make a report…
I also try to use the new “lightselect” RE… but all lightselect elements render out in pure black… in a simple scene it works perfect… hmhm??
