VRay Light Listener
Where does it go? A fresh install and it’s there, but after a couple MAX sessions, it’s gone.
It should be in the Tools menu. If it’s not there, try typing vrayRegisterMenus() in the MaxScript listener.
It was, because I used it yesterday, but it’s gone today. Maybe, it was removed when I installed SolidRocks. I’ll try what you recommended.
-- Type error: Call needs function or class, got: undefined
The same thing’s happened to me. I think it was after changing the UI from dark to light.
And unfortunately I get that error message in the MaxScript listener too.
Bobby, to do it the long way round, go to Customize → Customize User Interface → Menus, and drag VRayLightLister from the box on the left into the tools menu in the box on the right.
Cheers,
John
Hello!
Type registerVRayMenus() in the MaxScript listener. This should do the trick.
Best regards!
Come to think about it, I change the IU scheme to MAV.VRAY.
