VRay Light shows up within fog.
I’ve got a fog with a vray light. The vray light shows up in the fog even when “invisible” is set to true. Hiding the vray light doesn’t help either. This becomes more evident when you set the fog’s “Fog Background” to false.
Bill Dahlinger
rezn8
did you try checking optimize atmospheric evaluation in system?
Thanks for the quick response Mr. Angel! But unfortunatly, that switch doesn’t help.
Bill
yeah vray light needs some works, I think it would be revised in the newxt builds.
You will run into the same problem if you use transparent objects or objects with low visibility. The work-around is to set the fog type to exponential instead of linear. As for the “Fog background” issue, there is nothing that can be done at present.
