Vray Lights, multiplier 0 still effecting scenes
Hi All
I have a scene with 200 lights, 4 groups of 50ish instanced. The render time is 1 hourish.
First, I turn off 3 groups, ie 150 lights and the render time drops to 20 mins.
Secondly, I leave all lights on, but make the same 3 groups multipliers set to 0. The render time is back to 1 hour.
Why do lights that are effectively, and have no visible effect on the scene still course the render time to stay the same?
This is a massive problem for me as I have a walk though a tunnel where I could turn off lights behind the camera as I go to reduce render time, but not if the multiplier doesn’t turn off correctly.
Cheers
What happens when you turn the group of lights to off (instead of changing the multiplier to 0)?
Also, may i suggest you to try the vrayLightMonkey present in my scriptpack?
That will insure you’ll forget no light, be it instanced or not.
EDIT:I just tested it here, by the way, and under max9-64 and 1.5 final, setting the multiplier to EXACTLY 0 turns off the light(s).
Rendertimes show that quite clearly.
I tried to up to 72 lights (360/5) and it works as expected.
Maybe you indeed have some singular light not as instance of the others…
EDIT #2: There IS a slight difference between a 0 multiplier and a light entirely off. On a 640x480, it’s between 2.8 seconds and 1.6 seconds respectively (40% faster?), versus, of course, over one minuter for the lights properly on.
Still seems your scene is way off the mark, to me.
Thanks for the replys.
I have a test scene at work where I have a plane and a box, 2 lights, renders in 1min. I then make a massive box to one side and put a group of 50 instanced lights (the box means the rendered image is the same) and the render time is up to 1:20ish.
The fact is that with your tests lele, u did have a different in render time between the lights being off and the multiplier being 0, 40%. My render times are prob slightly different because of the materials etc. Still This must be a bug?
Thanks for your efforts. (Im testing on Max8-32, 1.5 final)
What kind of lights are you using?
Im using mainly all Vray lights, there are some max spots but not many. In my test scene I have only used Vray lights. I have not tested to see if all the lights were max then the problem goes away. I will try now!
EDIT: Ive re-made my test scene with only max pots, shadow map, and the outcome is better! The scene renders in 1.17 with 2 lights lighting the box and plane, with 200 spots behind a wall. with them off it renders in .44, and multiplier at 0, in .52. So with max lights the multiplier does have a render time effect of turning them off.
Strange why Vray lights dont do the same thing?
Vlado, is there any news on whether this is a vray only problem, and can be fixed?
Well, maybe 0.0 intensity is treated like any other intensity value, instead of an “off” state…
Yeah, I’ve added a special check for this; now if the multiplier is 0.0, the light is assumed to be off.
yeah, I think that might be the case. So, can it be changed so it acts as off?
EDIT: Vlado you got in as I was typing!! So its fixed!! wicked. And now for the big question, is it in the SP1? And when can we have it!!
Big thanks
Excellent!
