VRay Materials and Cosmos assets missing in network rendering
Hello everyone,
I was trying VRay preset materials on a running project (big mistake), and they look great but when I submit to network rendering all the textures are missing.
I have installed V Ray 5 in all our render nodes, but I noticed that in the material editor on the bitmap loader there is not a bitmap per se but a txt file to load the texture.
Even if I change the texture the map won’t load on network rendering.
Something similar happens with the new Chaos Cosmos assets when submitted to network rendering assets are missing. These assets also do not seem to be compatible with Chaos Vantage, or VRay for Unreal.
Your help is appreciated.
Fco
Hi @fco3d
Can you make sure that the Include maps option is enabled from the Network Job Assignment; or, alternatively, if you are using DR - enable the Transfer missing assets option. Moreover, Cosmos assets should render consistently across V-Ray, V-Ray GPU, V-Ray Vision, and Vantage.
Do share a scene file so we can investigate what may be happening through our contact form. Make sure to mention this thread in the email, thanks!
