Hi guys I was just flicking through the forums so see if there is a script of some sort to
apply Multi matte and Object IDs to selected groups of objects all at once and specify what IDs they should have?
I have a huge scene with quite a few objects and need to make this process less of a headache
ID have to script in UI and stuff. How would you want to control it? Select 1 OBJ and type in Number? basically a shortcut rather than Attribute editor or what?
Umm something like select like either one object and input a number or shift select 3 objects and then input the 3 different numbers?
or is that a huge ask?
whats ever is easier!
Well if you want 1 object then just select 1 object and keep attr editor open with slided to the bottom. You can just type the ID there. Then everytime you click on new object the UI should stay and you can type other numbers… regarding multi selection humh…maybe I’ll see what I can do ( could be fun exercise) but dont expect it to happen too quick :S.
