Vray not working
Couldn’t obtain license (4096) message is shown when start vray render in sketchup 2014
Sounds like perhaps your dongle is not plugged in? Or you are pointing at a license server that is invalid
exactly the same problem, sketchup 2016 x64, vray 3.4 b1, windows 10 x64, also set wibu key:(
Try re-installing. We’ve moved away from Dongle based licensing and there can sometimes be a conflict between v2 and v3 licensing. If the issue persists please email support@chaosgroup.com
The same problem here… :expressionless:
Hi All,
Upon your first installation, if you don’t login when prompted you may run into this issue. Here is some additional information that might be helpful:
The full set up and install documentation page can be found here: Chaos Docs
Just Install: Chaos Docs
Managing the new Online License Server: Chaos Docs
Hope that helps, and if any of you are still getting issues, please email support@chaosgroup.com for further licensing assistance.
