is there a way to put a vray object like the physcam or a vraylight into a quadmenu?
i can’t find any of these in the list.
unzip the 2 files attached into the ui/macroscript folder and restart max the 2 new objects should appear in a VRAYObjects list in the customise menu, you can then stick them in a quad menu. Should work with all flavours of max.
I’m not sure why Chaos have never done this before, by default, along side the other VRAY customise menu stuff and in the vray quad…guess I should put it as a wish list.
FYI: the macros attached are for a vray dome-light (which you can just change to whatever light type you need) and a vray plane object
vray_objects.zip (500 Bytes)
