Vray Physical Camera - no target??
Does the Vray physical camera not have a target point?? It is very difficult to move where the camera is pointing with out a target point to pick and move. Please advise.
Regards Peter.
It should have a target, how are you creating them?
when you create the camera dont you click on drag? that sets up the target point. dont know why you cant find it
yes it does. see if it is hidden or something.
actually it does have a target/focal point. even a couple of plans that indicates near and far dof.
edit:
a bit late I guess.
I see the grids but it will not select an end point for the target and there is not one visible. Nothing is frozen and if I go to the list to select there is only VrayPhysicalCamera1, and 2, with no targets???
Regards Peter.
weird, if you right click on the camera doesn’t the select camera target tool appear?
Figured it out. When I first put in the camera it was targeted but the target distance was so far that when I zoomed extents I couldn’t see my site. I turned targeted off to access the target distance and forgot to turn it back on. Viola! Just rechecked targeted and it was fine. Thanks for the help!
Regards Peter.
the only thing missing is a distance to target option like in the standard camera.
