Vray progress bar window
Hi, just upgraded to the latest Vray. found that the progress bar disapeared. Anyone has any idea where is this? TIA.
Hi aenc_randyc,
The progress is displayed in the lower right corner of the V-Ray Frame Buffer (VFB).
The render log is also something you can see in the VFB directly - in the Log tab of the right panel.
Because of that the progress window was no longer needed.
Konstantin
The V-Ray Log window has been reworked completely with added new functions. However, the progress bar has been removed from it.
You can follow the render process by monitoring the render progress bar under the V-Ray Frame Buffer.
