Vray Proxy and Cosmos assets slow down the scene
Hello
I have a scene setup with bunch of Cosmos assets / Vray proxies.
Now I’m setting up animation in this scene and these objects slow down the viewport so much, I couldn’t work on it. One asset is enough to slow down the entire scene. Even on preview quality.
I had to set up a manual expresso list for each of these to turn off when setting up animation.
Of course, when setting up the animation I need to also see those assets and the only thing to resolve the slowdown is to edit Cosmos asset into Vray proxy and then convert it to a full object + saving a bigger scene.
Both cosmos asset and vray proxy slow down the viewport, where the edited asset at 100% quality does not such a thing.
Any help resolving this?
Rafal
Hi @RwVision , we are aware of this issue and are working on fixing it soon. Thanks for your report and sorry for the caused inconvenience.
Hello RwVision​,
Please note that this fix has been added to the latest stable build which you can download and install from here. Thank you.​
Great, will check it
@zhanet.georgieva Is it the build from 05.08? Because the problem still exists.
Full geometry preview of cosmos asset and vray proxy slows down scene and when I edit it into a mesh, everything is fine.
Tested the new 08.08 version and I can confirm it works now. What a relief for the scene, many thanks!
Glad to hear the new version solved the problem for you!
