I want to use scatter for my trees/plants, they are vrayproxies already, but if I use MAXes scatter it will make a new object with all the scatter elements in it. Is there anyway to use scatter and vrayproxy for this? Other than manually instance trees.
Morne
October 19, 2008, 1:34pm
2
do a search for proxypainter
cs2010
October 19, 2008, 2:53pm
3
You can also buy this one : http://www.rendering.ru/index.php/plugins/vrayscatter/
Seems a little bit expensive for me … it’s just my opinion
bye
Thanks for the suggestions guys. Both interesting, although, yes vrayscatter seams expensive. Especially since Chaos guys will probably make a better “free” version for us vray users. I’ll try proxypainter.
cs2010
October 19, 2008, 3:32pm
5
thomes:
A chaosgroup’s vray scatter … hmmmm sounds good …
duke2
October 20, 2008, 2:00am
6
There’s no evidence to suggest this at all! In case people are getting their hopes up..
Neilg
October 20, 2008, 11:03am
7
There is already a scatter plugin that works fine with proxies, and most of the features of the icube plugin. And it’s free.
http://www.max3dstuff.com/max4/scatter/help.html
It was made for max4 originally, but still works in 2008+ and is still better than any other scatter plugin made since.
I’ll try this one too. Seams good.
Well, it seems not to load in MAX 9 or 2009… at my place
Neilg
October 21, 2008, 2:52pm
10
I was using it fine in max 9 x64…
Which one did you get, the max 4 or max 6 version?
edit: see attachment. Rename the file to .dlu and drop in your max/plugins folder.
scatter.zip (56 KB)
HAWF
October 22, 2008, 7:24pm
11
You can use also a script called advanced painter:
http://www.scriptspot.com/3ds-max/advanced-painter
take a look at the comments, there is a update for new versions of max.
