I have been reading over the site and posts for some time now and have learnt a s*$# load of stuff.
So first off thank you very much.
I haven’t really had to post anything before because I have found the solution to my problem in other posts but I was wondering…
Could someone please explain to me how VRay Proxys work.???
My thought was that you could make, for example, a bunch of houses in seperate files and make proxys of them. Then bring the proxys into a new file and not have a super huge file…I’ve found thats good to set up and render a test animation but, as I’m sure you all know, the proxys have a base colour…not the ones that may have been applied to the original model.
I hear different people talking about using proxys trees etc…how do you use then and clone etc with textures and materials applied???
I hope someone can help me out…this would make my scenes alot easier to manage!
Thanks again for all the help that you all constanly provide!!!
If all your objects are editable meshes then just select 1 object go to the modifier panel and select attach list
Select the objects you want to “attach” to make a single model and hit the select button
You can probably stick with the defaults for the material options when it asks, hit ok and your done.
It will create a multi/sub material for you so just save that to a mat lib, export the new mesh to a vray proxy.
Then just place the new vray proxy into what ever scene you are working on and apply the multi/sub material you saved earlier to the vray proxy object, hit render and your done
if you need further into on attaching editable meshes I suggest looking into the 3dsmax user reference.
Under normal circumstances I prob would have given the same answer RErender but I was waiting for a render so I had a few more minutes for a couple extra lines 8)
