Vray rendering issues on Mac
Currently trying to locally render in my M5 Mac via Vray. My coworker who uses PC can do it with the same setting but I can not. I only see a black screen, and the renderer starts for 1 second and then it stops
Which host platform are you using?
Hi I am using Maya 2027.
Does it happen on any scene or on a particular one (if the latter, do send it, please)? Any warnings/errors in the VFB log?
Hi, just looked at different scenes and they are affected the same way. (Renders are all blank). Also there are no VFB errors I could see on the log.
Which V-Ray version are you using? Could you share the Mac’s specs? Also, which engine/device are you trying to render with?
Also, just to be sure, is there a light in the scene? Check the alpha channel.
Hi it would be:
•V-Ray 7 for Maya, update 4 DR2 (v7.40.04 from Jul 27 2026)
•Mac Golden Gate 27.0.1
•As to the engine tried both. Vray and Vray GPU, both results on blank.
•As to light scene, it is set up, also tried a fresh scene with a dome light yet same blank results.
I think it’s best if we do a remote session; otherwise, I’ll only be guessing. Write me a PM when you are available.
Hi sure I can private message you. Just no idea how to do it in here (Didnt see a message option on your profile). Is it via customer service link you mean? (The link in your signature)
Wrote you a DM. You can access them in Profile > Messages.
