I have set my render background as per this solution (V-Ray Rendering white halo around objects with transparent backgrounds - Issues - Chaos Forum).
e.g.
In VRAY the render looks great:
But when I import it into Paintshop Pro and do a backfill of black it has a transparent edge, which is not what is needed.
(I do have pictures of all of this, but when I try to upload them I get the following message: Missing PHP temporary folder; check upload_tmp_dir)
Hi rusty_badge,
The people responsible for the forums have been notified and hopefully the problem will get resolved soon.
As for your rendering issue:
If you have rendered upon a black background in V-Ray, there should be no hallo effect in the post processing app.
I’ll have too take a look at the rendered image or your scene to help you further.
Konstantin
Settings:
Render in Vray (no feathering)
Showing Feathering
PS Konstantin thank you for replying.
Hi rusty_badge,
It is expected to see the hallo from the attached image in case you use something like a ‘Paint Bucket’ to fill the background.
The reason is the aliasing at the alpha border. It is actually a good thing. Without it the alpha border will be pixelated.
The proper way to do it is to create 2 image layers in the post processing app - the top one is your image, the bottom will act as a background.
You then fill the bottom with the desired color:
Konstantin
Konstantin that was an easy fix. Thank you for taking the time as it just saved me days of stressing!
