Vray RT Benchmark for download
Vray RT GPU Benchmark
i created a small BENCHMARK file with 3dsmax and vray RT 3.4 as a production mode.
all you need to do is to download this file and press the render file
your GPU card will stop to render when he complete to and hit the 0.01 noise value .
i know this is not completely unbiased test because he run first Light Cache and then move to pure brute force.
as you can see i have a old GPU card (750ti) so my test end with 15 minutes to hit the 0.01 noise level.
so please run this scene and capture you screen to share your render time
and you gpu card
THE LINK HERE:
THANKS
this is for users with 3dsmax 2014
This bench mark has no displacement, no transparency, no reflection (okay a little bit)…no HDR… it isn’t a very good test.
I know you were looking for benchmarks…Have you these?
http://forums.chaosgroup.com/showthread.php?89406-Titan-X-Pascal-benchmark
and this one:
http://forums.chaosgroup.com/showthread.php?88951-Amd-rx-480
there is scene you can post here for checking the vray rt?
any chaos group one?
as some of you ask… here the same scene but with some materials on them… hair, glass, car paint and so on… please all of you that take part of the previous test do this test and we see if your gpu is keep on with liner power as cpu or its get slow with the scene get complex.. Thanks!
here the link
12m 03s - Quadro K4200 (single)
6m 39s - Quadro K4200 (Dual)
1m 59s
3 x GTX980ti
4m45s Quadro M6000
3m38s
(1x) GTX 980 ti
(1x) Quadro K4200
4m20s
(1x) GTX 980 ti
11m 59s
(1x) Quadro K4200
Dell Precision 7910
Xeon E5-2640 @ 2.6 GHz
16 GB RAM
SSD HD
Windows 10
5x 1080 AsusFE DR(2 machines) 58sec
It would be faster on one server with 5 gpus but they are busy right now, anyhow scene is too simple to get real impression about GPU vs CPU
With scene initialization and all that it was 1m 9s
Edit: give it another try(as sequence of 2 frames) here are the results. Faster overall results but it varies in between, probably because of network.
1m4s
can anyone able to test 1 of the interior of evermotion on 1 card gtx 1080 8 giga
or this is not much memory?
im sure you have some interiors scene
it will be great!
thanks
(3) Titan XP’s
1m 8.7s
Singe GTX 1080 8GB
Secound Frame 6:35min
Edit:
Which one? If its free I’ll test.
I’m in a GPU testing mood today. :wink:
1 minutes and 29 seconds. GTX980ti and GTX1080 Founders Addition.
that does not look right…wrong view port?
I downloaded both the benchmark scenes and both open the same way, with one camera, and looking at the same thing.
7:12 on my 970 ..loading before rendering took almost 20 second, is that normal?!
I was curios to see my dual xeon (2650 V3 10 core each ) performance so I did a test with the default settings and it was only 5:05 !
So 2 of my 400 $ VGA will beat my dual xeon ! looks interesting ..
Pretty odd, I think. on my 970 (msi twinfrozen) render done in 5:35 and on my friend 970 done in 5:44
