hiho
if i have to render an extern scene I must open and edit the save path for GI and some other setting
if loading need 5min i waste ages of livetime
how whould look a script wich run before render start to enable disable “dont render final image”
or “if GI enabled and GI = IRRmode set GI mode multiframe incremental and save path to X”
I wonder why Vray can not be accessed by render comandline directly
comparing to Maya and Final Render I can modifiy all importend FR settings directly via cmd
is there no way for Max n Vray but script ?
Very easy, 2m script. incoming
global VRayEnabled
global rlt_QuickRenderSetup
global isDontRenderFinalImage
fn VRayEnabled = ( if (matchPattern (renderers.current as string) pattern:"*V_Ray*" ignoreCase:true) then true else false )
try (destroyDialog rlt_QuickRenderSetup) catch ()
rollout rlt_QuickRenderSetup "Quick Render Setup" (
checkBox chk_dontRenderFinalImage "Don't Render Final Image" checked:false
button btn_Execute "Execute"
on rlt_QuickRenderSetup open do (
if VRayEnabled() then isDontRenderFinalImage = renderers.current.options_dontRenderImage
chk_dontRenderFinalImage.checked = isDontRenderFinalImage
on chk_dontRenderFinalImage changed state do (
isDontRenderFinalImage = state
on btn_Execute pressed do (
if VRayEnabled() then (
local vr = renderers.current
renderSceneDialog.close()
vr.options_dontRenderImage = isDontRenderFinalImage
if vr.gi_on == false then (
if (queryBox "Turn on GI?" title:"GI is currently off") then vr.gi_on = true
if vr.adv_irradmap_mode != 1 then (
if (queryBox "Turn on Multiframe Incremental?" title:"Multiframe Incremental is current not on") then vr.adv_irradmap_mode = 1
if vr.gi_on and vr.adv_irradmap_mode == 1 then (
-- GI is on and Irradiance map is set to "Multiframe Incremental"
if (local saveFilename = getSaveFileName caption:"Select where to save the Irradiance Map" types:"vrimg(*.vrimg)|*.vrimg") != undefined then (
vr.adv_irradmap_autoSave = true
vr.adv_irradmap_autoSaveFileName = saveFilename
) else messageBox "IMAP Save not set" beep:false
) else messageBox "VRay not the current Renderer!" beep:false
createDialog rlt_QuickRenderSetup 200 55
thanks a bunch but by far too much script
i just like to run it via cmdline before render starts so
“renderers.current.options_dontRenderImage=true”
and
“renderers.current.options_dontRenderImage=false”
is enough to switch that
lets see if i can decrypt ur script to switch the GI modes and save path/name (will be passed from backburner to script before render starts)
