VRay Shadow Density and Colors
Hi, is there a possibility to change the VRay Shadow Density and Color
like with usual max shadow? I need this to tone down a shadow in a
scene and I miss this feature…
Thanks a million, Rob
yes u can
in the same way but u have to untick the trasparent shadows option if i correct remember
hope it helps
Yep, you have to turn off the “Transparent shadows” option in the VRayShadow parameters. Note that transparent shadows will still work, only the shadow color will not be taken from the material transparency, but from the light settings.
Thanks Pengo and Vlado, very cool!
Here is a direct link to the help/example section, how this works:
nikki Candelero
