vray silent install ( inside 3dsmax 2020 deployment )
Trying to install 3dsmax 2020 including Vray to our renderfarm - obviously goin for a silent install.
If I run the below line in cmd vray installs fine
vray.exe -gui=0 -quiet=1 -configFile=“config.xml”
The same commandline defined inside the 3dsmax deployment and the vray installer suddenly can’t find config.xml, any ideas as to whats going on?
You can’t execute cmd commands with unc path I believe. You can try specify explicit path to the config file since it won’t know where it’s trying to run the command.
writing the full path to config.xml in commandline paramaters worked exactly as you suggested - THX!
