Vray sky on RT, Reflection map on sand
Hello there,
i have some white dots while using a reflection map and using Vray Sky.
if i set sun to invisible at Vray sky, i dont get this. and speed is quite different…
some kind of bug?
Hello Mario,
The result you got with the white spots is normal.
Vray Sun is a very bright lights source - and highly reflective materials will reflect it with such very bright hot-spots.
You can remove them by turning of Sun’s visibility like you did.
