VRay Sky
is there a possibility to turn the Vray Sky at 180 degree?
well map it to a vray dome light.
It’s been some time since i last visit this forum… how do i use a VRay sky. do we have it in 1.47.3?
nope. you dont have it.
as for turning it 180 degrees…why?
For the same reason you would rotate a hdri or any other texture I suppose?
to create a feeling of vertigo?
well if you want to rotate it around the z axis…then you just have to rotate your sun node. If you mean rotating it around x or y then i assume you cant.
Only mehtod i’d have in mind would be rendering a spherical HDRI and using the map :stuck_out_tongue:
Thorsten
rotate the sky 180deg :shock:
Probabaly easier to turn your camera upside down and then rotate your geometry.. hahaha
I have to create a kind of under/Overwaterworld :?
and it would be very nice to use the Vray Sky for illumination/Background,
but turned.
to turn the sun doesn’t help, even not to use it in domelight.
Daforce: haha thats a great idea :smile:
best regards
jonas
definitely render an HDR panorama and stick it as a BG then.
Lele
