OS: Windows 11
3DsMax 2021
Vray Core Version 6.10.08
(running vray spawner simply by double clicking the “vrayspawner2021.exe” and it stays in the system tray)
I am using Vray for network rendering in my company. We have connected a few PC in a local network to use for network rendering.
We have one main machine where we are sending the task to render. It is our main Render Machine. Lets call it WS-07
And we got 2 other machines ( WS-08, WS-09 ) where we are running VraySpawner2021 to contribute in the render process.
At the 1st time, when we start the Vray Spawner in the WS-08 and WS-09, it runs perfectly without any issue. it Connects to the WS-07 and contributes in the rendering process.
But after a few renders, (there is no specific time to mention) it doesn’t take any render task from WS-07 the main node.
To check the problem, we used the “DR check tool” provided by VRay for troubleshooting. We found that the machine is Status:busy Connected:0.0.0.0
The error looks like this
C:\Program Files\Chaos Group\V-Ray\3ds Max 2021\bin>vraydr_check.exe -host=192.168.101.208 -port=20204
Status:busy
Connected:0.0.0.0
Num processors:32
V-Ray core version:6.10.08
V-Ray revision info: May 2 2023 16:33:55
This problem is solved by closing the Vray spawner manually and restarting it again.
Now its very disturbing to check the status of each spawner again and again, and restart the Vray Spawner.
Why is this happening? why is the status is getting busy while connected to an IP 0.0.0.0 ?
Additionally, to solve the issue I **enabled** the **restart servers** from vray DBR configuration settings.
here is the code inside the **vray\_dr.cfg** file:
192.168.100.210 1 20204
restart_servers 1
list_in_scene 0
max_servers 0
use_local_machine 1
transfer_missing_assets 1
use_cached_assets 0
cache_limit_type 2
cache_limit 100.000000
render_region_warning 1
But it didn't work out. Could anyone please tell me what am I missing?
Thank you for your help.
