Vray Sun crashes when trying to animate position
Hi I am encountering crashing to desktop in Maya 2024.1, with Vray 6.1. With a vray sun (manual position checked), any time I try to set a key to animate the sun postion, it causes Maya to freeze then crash to desktop. I then thought to see if perhaps I can set keys via any of the Time attributes, and attempt to set keyframes on any of those also causes maya to crash.
Thank you for the report, jling​. The crash reproduces with Maya 2024.1 and I’ve logged it in our internal bug-tracker (id: VMAYA-12322).
VRaySun can still be animated as expected with Maya version 2024.0 if that is an option for you until there’s a fix.
Has this been fixed?
Yes, the fix is in the V-Ray for Maya 6.20.00 release as well as in 6.10.02 nightly builds 32422 from 18 Jan and later.
