VRAY TOON LINES NOT RENDERING
Hi Guys,
I am working on a project for work, its nothing fancy just a quick render.
I am having a bit of trouble with VrayToon Material, I created a White base material and then linked it as my base material for Vray toon Material.
I am using Vray Sun, and when i render my model not all the lines appear, i have attached some images to illistrate this. It is very annoying.
Does anybody have this problem? or does vray toon still have bugs, until it is re-relseased in the next update??
Thanks everyone!!
Re: VRAY TOON LINES NOT RENDERING
I’ve never used the Tool material. I find it quicker and with better result to export a B&W line image from Sketchup and combine them in post.
Hey , i guess penguin does the same and it’s much easier.
Isn’t Penguin Rhino only?
You just need to adjust the V-Ray Toon Material “Overlap Threshold” parameter until you are happy with the results. It takes a bit of trial and error as every model is unique and the level of smoothing applied to different groups will affect the outcome.
and re: your topic title, THERE’S NO NEED TO SHOUT. You’ll get more attention using just plain old Lower Case. :wink:
Thanks for your help guys!!
I dropped the overlap threshold to 0 and that did the trick perfectly!!
Cheers!!
P.S sorry for SHOUTING! :slight_smile: :slight_smile: :slight_smile:
