i know i can drag-n-drop into the mapping source, but is there a way to drag-n-drop without having to hunt on the network for a bitmap?
for example, using the slate material editor. i’d like to drag a bitmap from open network folder into the slate material editor - and then drag a connector from it to the vraybitmap.
wow sorry guys, i never even thought to try drag-n-drop into the white text-box above reload | view image | locate. that works perfect! i just drag it there from the network folder instead of dragging the bitmap to the slate material editor field (ha, which creates a 3dsMax bitmap). thanks!
