as i understand it (and as described in the help files) the doublesided setting should be the same as combining an inverted dirtmap with a non inverted one.. shading along edges and also creases.
in both viewport ipr and production progressive render (cpu) the doublesided tickbox has no effect, i get either creases or edges, depending on wether invert is ticked.
anyone from vray to answer this… would be cool if this would work how we understand it…faster than vraycomptex.else it would be good if someone could explain it.
The thing is that “double sided” makes the effect to appear on the backsides of the faces where it should be calculated initially depeding on the normals, it doesn’t change the place. It’s kind of confusing, I admit. For the effect you desire you can use VRayCompTex with 2 VRayDirts (invert normals on and off) or VRayCurvature.
ok thanks. maybe change the description in the help file as it sounds like it should do what i describe.. its also doubly confusing since im duplicating a corona scene where “inside, outside, both” are the options in coronaAO, and that does behave as i describe.
