its a new feature or why “work with transparency” checkbox is missing in vray 5? Because now we cant tell dirt to work with transparency. Its also missing with new AO pass, which also doesnt work with transparency.
The option was renamed to “Ignore invisible objects”. Note that it is not yet available in the VRayAO render pass. I’ll forward the request to the development team.
EDIT: Your request was added to the logged improvement request (internal bug-tracker id: VMAX-10914).
Thanks, ignore invisible objects works. ![]()
Ignore invisible objects is dimmed, the check box is not checkable. latest V-Ray.
this is extremely important, light plans intersecting geometries are calculated as AO plans.
@wessam It is not yet supported on V-Ray GPU, I’m afraid. A re-render of the image for the AO (whilst hiding transparent objects) can be used as a workaround.
