I have a (low poly > turbosmoothed > edit poly) rock that I need to grow fun on.
Vray fur attached correctly, but the fur grows straight out (following the poly normal, I assume) and neither the bend parameter nor the gravity parameter have any effect on the fur whatsoever. Other properties, like taper, work correctly.
In the same scene, I can grow fur on a sphere with no problems. Bend and gravity behave as intended.
