To add to this, I have always found that setting a light source (vray light) to cast the correct amount of light on surfaces, always produces an ugly light source, as in completely blown out (if visible). This is working with LWF. I always have to hide the light and do other fakey stuff to make the directly visible light and fixture look correct. When photographing interiors and exteriors, the light sources often look a lot less bright then when vray calculates them. Having to always remake the physical appearance of a lamp after setting it up to shoot the right amount of light (according to its physical properties), seems a bit of a waste of valuable time, when one would expect it to fit the first time around.
There is a bug in mental ray where the exposure control is not applied to the directly visible IES light shapes - you can verify this very easily (regardless of exposure control settings, the RGB values over the visible light shape remain exactly the same). V-Ray on the other hand is correct in this regard and the camera exposure settings correctly dim the visible light shape.
I can assure you that V-Ray is correct in this regard. However in the real world, you almost never directly photograph a light source. In the photos that psa posted, it is a lamp shade that is on the photos, not the light bulbs.
Looks correct to me. The exposure difference between the tungsten type lamps for the night shot is something like 8 stops different than the daylight one. You would expect the diffusers on the lamps to be quite greyed out.
The photo reference is deceptive because they look to be pro shots which may mean some good light/exposure balancing on set or retouching/processing to achieve that. Probably both. It would be more instructive to take a camera yourself and actually shoot a similar lighting scenario to see what you find.
I agree with trixian in most regards, but I have actually been considering doing what Brett Simms is suggesting. So: I will take a photo of the Glo-ball myself, so I have a precise reference. I will then do a test render of my 3D scene without direct sunlight. It will be interesting to see what we end up with after that. I do suspect though that the light from the lamp on the table still will look to low without multiplication. But I agree that possible mistakes or errors should be ruled out so we/I don’t make any wrong conclusions.
Just to be clear: I agree that you would need to multiply the light intensity. In reality you would have to in order to balance direct sunlight with such a low power light as well. The only question is how much.
Actually, I’ve noticed the problem with VrayRT, realistic values are working well in RT, but the same value in the VFB renders the light like if it was OFF. You have then to muliply the value by 1000 or more to get the same result as you had in RT… strange, never knew if it was a bug or a limitation of the LWF method
