I am having trouble adjusting the power of my IES lights in a scene. Doesnt matter what value I put in the “power” slot the output is always the same.
Is the power value over-ridden by the IES manufacturer data loaded into the IES slot?
Re: IES light power setting
Power is in Lumens
By default the power is set to 0, which means that it will use the IES file itself to determine the proper power. If you’re not getting the results you like, you might want to try a different IES file. Power should only be changed for slight adjustments.
ok, thanks for the quick response Dkendig I’ll try another IES file.
if you are using phys cam you should really crank it up .. go extreme.. I’m serious..
not necessarily, it all depends on the ies files you use. Try getting some from various manufacturers, and see which ones you like best. Sylvanna, GE, Eclipse, etc. It helps to search for the term “photometric data” as well when searching for ies files.
By the way do you know of any tool to convert .LDT files to .IES? Many manufacturers use eulumndat.
Another question…
What is the unit used for the IES Light power parameter (lumens, candelas..)?
Devin wrote
Power is in Lumens
Chaos: Industry-leading design and visualization software
So you are saying one should get a brighter image by manipulating exposure settings on camera instead of overpowering the ies light?
This can be a bitch if you are dealing with environment lighting such as sky for example.. it would overexpose the shot…
any ideas?
You must setup first the light with the most contribution in the scene. Usually the sun and the physical camera. Then you could setup the artificial light as IES, rectangular, spotlights or omni lights. Remember that the physical camera control the exposure of every single light in the scene, so it is better to get a decent illumination just with the physical camera and then add the other light and adjust their multiplier or power to fit your style. I said style because every artist have their own style and workflow and all are good if they can get a decent render. ![]()
It is true that you have to increase very high the IES power to get your desired effect, the reason is because the Physical camera control the exposure of the IES light as well. If you don’t use the physical camera, the default IES power should be enough.
The question that I was trying to answer was that the power of the IES is in Lumens. ![]()
Best
some IES files are brighter than others also, so it all depends on the IES file you use too. Setting some ridiculous power setting is silly though. Just get IES files that provide the proper level of illumination. Try more than one company’s IES files until you find one that suits your needs. If you set anything for the power value, you override the illumination information in the IES file, “power” isn’t called “multiplier” for a reason. There are also tools out there that allow you to edit or create IES files, you might want to look in to those as well.
Could you attach an IES file as example?
Which doesnt need extreme values when using phys camera?
here’s an example of an ies light, completely default settings, no sun, physical camera is on.
The ies file is named: 80PAR-HIR-SP10_(27216).ies
It can be found on eclipselighting.com: http://genet.gelighting.com/LightProducts/Dispatcher?REQUEST=IESCATEGORYPAGE
Now keep in mind, this is just default physical camera settings. If you’re doing an interior, and you’re using an IES light that represents the photometric data of a light that should be used indoors, you probably want to adjust your physical camera’s settings to adjust to the indoor environment. If you’re doing an exterior render, then you want to be sure you have an IES file for an exterior light that is bright enough to compete with whatever sunlight you have in the scene. For example, the renders below were done with an IES light that has a much lower intensity:
Physical Camera ISO = 100
Physical Sun Enabled = True
Physical Sun Enabled = False
Physical Camera ISO = 3200
I feel nomatter which ies file u use, the light power is always underrated. For example in real life, in the scene u set up would’ve been overexposed with an iso that high. And on vray it barely scratches… So you find yourself always having to compensate. Either camera or the light power setting.
Also, very often people use IES files for spot lamps, mr16, par, ar, … The power of these is measured in candelas, not lumens.
Im not sure what is going on there then, I found it to be the complete opposite to what you describe. My IES lighting is too intense for my scenes and needs toning down…
it I leave the IES light power on zero as advised, I have to use extreme settings on the camera in order to see the light, for example: F stop 2, ISO 3200… making it impossible to use sun and ies lights at the same time in some scenes..
I will post some images…
Link for the image:
http://img193.imageshack.us/img193/8307/capturehul.png
as you can see, the IES file is from a fairly powerful lamp (from GE) and this camera settings does not represent a real world result.. as if the engine is not tuned for real life physics … I am no programmer, but as a lighting designer I should know one thing or two about lights. I don’t know… maybe its is my settings or something I haven’t figured out yet!
Thanks in advance for everyone replying!
Cheers…
Which version of vray is this you are using?
Installed version is 01.48.83
But on the render stamp it says Vray Core 1.70.00
I’m not sure why you are getting these results. Let me know which IES file you are using so I can test the same and show you the result. I get mine from GE website.
