As the title says. Can we make that checkbox ticked by default when creating that renderelement? Recently had to rerender dozens of scenes because I missed that one. And I can’t even think of a reason why one would want to render without that box ticked.
Ok, will make a note about it.
And it took a minute to get answer! Thanks guys!
Can this be reconsidered to be done? Missing in 3.6
What’s the advantage of color mapping being enabled by default? If you are compositing this in post wouldn’t you want a completely linear pass by default?
If you don’t enable color mapping, stuff like exposure etc. will not be transferred to the MtlSelect elements. That way our MtlSelects for carpaint for example will not match the beauty RGB, because it is darker/brighter. Some artists here often overlook that little checkbox and the rendered output goes to the garbage can. The MtlSelect will still be linear, but properly exposed.
