VRayMtlWrapper not supported?
according to this list (V-Ray for 3ds Max) the VRayMtlWrapper material should be supported in GPU mode. However it seems that the Matte properties have no effect. In CPU mode it works without issues.
Is that a bug?
Mind if you attach a sample scene so we can have a look?
there are 2 issues:
1. The Matte doesn’t work unless the AlphaContribution is between -0.9 and -1. Anything apart from those values will make matte properties to not work.
2. If the AlphaContribution is between -0,9 and -1 AND in the BaseMtl is anything else than a VRayMtl (for example a VRayBlendMtl) it will make it matte BUT the shadow options don’t work.
So the only way to have the VRayMtlWrapper work in GPU mode is to have an AlphaContribution between -0,9 and -1 AND use a VRayMtl as the BaseMtl.
CPU doesn’t have any of those issues.
I attached you a sample scene.
Best,
Jonas
matte.zip (75.9 KB)
1. In GPU, only Alpha Contribution -1 (Matte must be active) ̶a̶n̶d̶ ̶1̶ ̶a̶r̶e̶ ̶s̶u̶p̶p̶o̶r̶t̶e̶d̶. Decimal values, one and zero, are not. This is already logged (internal tracker ID: VGPU-2828 ).
2. I can reproduce this and will log it (logged as internal tracker ID: VGPU-6815). Is there a specific reason to use a VRayBlendMtl for the shadow catcher?
HI:
1. Actually +1 also doesn’t work. Only values between -0.9 and -1 as I mentioned. You can try it out. If only -1 is supported you might want to set this value internally regardless of what value is chosen in the menu as a workaround. Otherwise it will cause confusion. I only found this out after extensive testing.
2. I have a usecase here as I’m working on a tool/script where you can easily switch between the matte and an standard option for the floorplane and the basematerial HAS to be a VRayBlendMtl. So that’s how I noticed that.
Is it a very common usecase? Probably not, but as said in CPU it works without issues. It might cause confusion you just want to create a matte shadow pass on your existing scene by putting a Wrapper in front of your existing material and no shadows show up.
I stand corrected, it disables the Matte. It’s better we support the whole parameter fully, rather than settings temporary defaults.
Is it a very common usecase? Probably not, but as said in CPU it works without issues. It might cause confusion you just want to create a matte shadow pass on your existing scene by putting a Wrapper in front of your existing material and no shadows show up.[/QUOTE]
Okay. Already logged the issue (edited my previous post with the ID).
Hi, in this case I would remove the VRayMtlWrapper from the supported materials in the GPU page alltogether in the meantime. As you default the AlphaContribution to 1 (which doesn’t work) it will just register as not supported to the average user. Since it shows as supported on the feature page I just wasted quite a bit of time to find out that it actually is not suported. Or make a note on the page itself.
