I’ve tried using the random by particle ID in the MultiSubTex, but it just assigns id 3 to every particle.
Is there a particular way it should be used?
It seems to work for me for some simple tests - so could you share a simplified version of your scene ?
Yavor
Hi Yavor
Attached is just a quick test I did.
The pic shows particles on the left with random by particle and baked particles on the right with Random by render ID.
Random by Particle color.zip (572 KB)
Thank you for the scene. I’ve managed to reproduce the problem here. I’ll write here when we fix the issue.
Yavor
was this fixed? I’m running into something similar.
thanks,
V Miller
Sorry but we haven’t yet fixed this issue.
Yavor
